Quick Links
How to set dram region to cacheable?
#1
Posted 31 October 2012 - 07:34 AM
I am a newcomer to ARM world.
I was working x86 platform in these years.
So, i have a question about how to set dram region's cacheable attributes.
Take my ARM development board as an example:
It has 1GByte DRAM, 4MB NOR Flash, 64MB Nand Flash.
So:
1. How to set some parts of 1GByte DRAM to cacheable(write back)?
2. How to set 4MByte NOR Flash region to cacheable , to enhance uboot's execution speed?
With x86 CPU, it had MTRR registers to do these things, so how to do these things on ARM platform?
I have read some arm documents, it seemed doing these things by creating page tables , right?
Any tips will be appreciated!
best wishes,
#2
Posted 01 November 2012 - 11:36 AM
Assuming that you are using a Cortex-A processor, then it's in the translation tables. On reset, the Memory Management Unit (MMU) is disabled. It is the MMU which is used to define which addresses are cacheable, readable, etc.... To turn on the MMU you must first set up the translation tables. These are the tables which tell the MMU what the attributes are.
#3
Posted 09 November 2012 - 04:53 PM
I have a very similar question !
i would like to separate my DDR memory into 2 sections :
one, used by the processor only, this section have to be cacheable
the other shared with external processes. this section mus be set as a device.
i'm working on a Cortex A9 inside a Xilinx's Zynq.
i could find a library with these functions :
void Xil_DCacheInvalidateLine(unsigned int adr);
void Xil_DCacheFlushLine(unsigned int adr);
void Xil_DCacheStoreLine(unsigned int adr);
void Xil_ICacheInvalidateLine(unsigned int adr);
void Xil_L1DCacheEnable(void);
void Xil_L1DCacheDisable(void);
void Xil_L1DCacheInvalidate(void);
void Xil_L1DCacheInvalidateLine(unsigned int adr);
void Xil_L1DCacheInvalidateRange(unsigned int adr, unsigned len);
void Xil_L1DCacheFlush(void);
void Xil_L1DCacheFlushLine(unsigned int adr);
void Xil_L1DCacheFlushRange(unsigned int adr, unsigned len);
void Xil_L1DCacheStoreLine(unsigned int adr);
void Xil_L1ICacheEnable(void);
void Xil_L1ICacheDisable(void);
void Xil_L1ICacheInvalidate(void);
void Xil_L1ICacheInvalidateLine(unsigned int adr);
void Xil_L1ICacheInvalidateRange(unsigned int adr, unsigned len);
void Xil_L2CacheEnable(void);
void Xil_L2CacheDisable(void);
void Xil_L2CacheInvalidate(void);
void Xil_L2CacheInvalidateLine(unsigned int adr);
void Xil_L2CacheInvalidateRange(unsigned int adr, unsigned len);
void Xil_L2CacheFlush(void);
void Xil_L2CacheFlushLine(unsigned int adr);
void Xil_L2CacheFlushRange(unsigned int adr, unsigned len);
void Xil_L2CacheStoreLine(unsigned int adr);
but it doesn't enable disable cache for only a section of the DDR.
i saw there is a stuff called PL 310 who looks like the L2 Cache, and also some explanation about MMU and translation table but i could not find
a simple example that i could modify to make the job. I hope someone could help !!
regards.
Thomas.
#4
Posted 23 November 2012 - 03:45 AM
On your other reference to L2 Cache with Cortex-A9, this is an external IP on AXI bus. What exactly is your concern with L2 Cache?
regards.
Thomas.
