Login
Important information
This site uses cookies to store information on your computer. By continuing to use our site, you consent to our cookies.
ARM websites use two types of cookie: (1) those that enable the site to function and perform as required; and (2) analytical cookies which anonymously track visitors only while using the site. If you are not happy with this use of these cookies please review our Privacy Policy to learn how they can be disabled. By disabling cookies some features of the site will not work.
ARM Community: DS5v5.10 Linux Kernel & Application Workshop with Snowball - ARM Community
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
DS5v5.10 Linux Kernel & Application Workshop with Snowball Rate Topic: -----
#1 User is offline   Fadil
  • Member
  • Pip
  • Group: Members
Posted 06 July 2012 - 04:18 AM
Hi all,
Pardon my noob status - I'm trying to follow the above tutorial but stuck at downloading the Linux Kernel to my Snowball (page 89). The instruction reads "In order to find the kernel sources, duplicate the deb line in /etc/apt/sources.list.d/hwpack.linaro-landing-team-ste.list and replace deb with deb-src". How do I carry out this instruction? I'm really confused!
FadilSG
0
#2 User is offline   scott
  • Regular Contributor
  • PipPipPip
  • Group: Members.
Posted 06 July 2012 - 08:30 AM
You need to edit the file on the target. There are various ways to do that. You could be use vi or some other editor over the serial console. You could use Remote System Explorer in Eclipse to open and edit the file. Since it's small, you could compose the file on the host and then use cat [sic] and paste over the serial console.
1
#3 User is offline   Fadil
  • Member
  • Pip
  • Group: Members
Posted 06 July 2012 - 08:52 AM
So I just need to open the file in RSE view on DS5 and replace deb with deb-src? OK thanks for the info!
0
#4 User is offline   scott
  • PipPipPip
  • Group: Members.
Posted 06 July 2012 - 12:41 PM
Mostly ... the instructions say to duplicate the line and make the change in the copy. The file will have both the original line and the changed copy.
0
#5 User is offline   Fadil
  • Member
  • Pip
  • Group: Members
Posted 09 July 2012 - 09:15 AM
Ok, got that. Now I'm stuck at another part of the workshop. I'm doing Debugging Kernel Initialisation after MMU is turned on (skipped 'debugging before MMU is turned on' as it seemed optional). When I completed debug configurations, it landed at this stage (see attachment). How to fix this?
Attached File(s)
0
#6 User is offline   scott
  • PipPipPip
  • Group: Members.
Posted 09 July 2012 - 04:56 PM
The screenshot looks pretty much as I would expect for connecting to a running, idle kernel. Except that you've managed to link the Commands view to "U-Boot". You probably want to change it to "Linked: kernel".
If there's a different problem, can you give more details of what you expect and what is different?
This post has been edited by scott: 09 July 2012 - 04:56 PM
0
#7 User is offline   Fadil
  • Member
  • Pip
  • Group: Members
Posted 10 July 2012 - 02:30 AM
OK I've changed the command line to kernel. I've actually went back to debugging before the MMU gets turned on. A few bumps along the way but I managed to sort them out.
Currently I'm at page 24. My snowball still hasn't fully booted up Linux, so when the instructions state, "When the kernel finished booting it will prompt you to login. Type ls to the terminal window to list the files in the current directory", what does it mean? I have to let Linux be fully loaded? I tried that and I can't proceed to the next instruction.
FadilSG
This post has been edited by Fadil: 10 July 2012 - 10:06 AM
0
#8 User is offline   scott
  • PipPipPip
  • Group: Members.
Posted 10 July 2012 - 01:24 PM
Yes, if the debugger has the target stopped, the kernel won't be able to finish booting. I think that page is missing: "Clickthe Continue button and let the kernel finish booting." above "When the kernel finished booting..."
0
Share this topic:
Page 1 of 1
