Login
Important information
This site uses cookies to store information on your computer. By continuing to use our site, you consent to our cookies.
ARM websites use two types of cookie: (1) those that enable the site to function and perform as required; and (2) analytical cookies which anonymously track visitors only while using the site. If you are not happy with this use of these cookies please review our Privacy Policy to learn how they can be disabled. By disabling cookies some features of the site will not work.
ARM Community: [Cortex-M3] MPU questions - ARM Community
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
[Cortex-M3] MPU questions Rate Topic: *---- 1 Votes
#1 User is offline   MarcoMac
  • Member
  • Pip
  • Group: Members
Posted 11 June 2012 - 09:00 AM
Hello everyone,
I'm studying the MPU of the Cortex M3 for a university project and I have some questions...
  • After I set up a region, where the MPU saves the informations on that region?
  • In the MPU Region Attribute and Size Register the bit C (cachable) refers only to an external cache, right? Because CM3 doesn't have a cache.
  • In the same register, if TEX=b000 C=1 B=1 we have "Outer and Inner write back. No write allocate". What it means "No write allocate"?
  • I found that post on the "Strongly Ordered" memory type. is it correct?
    Quote
    Load/stores to Normal memory may result in any size and number of transactions being presented to the memory system, e.g. a byte load might appear as a word read to the memory, or two neighbouring half-word stores might be merged into a single word write. In addition, near-arbitrary caching and prefetching could be performed.
    Explicit load/stores to Device and Strongly-Ordered regions always produce the exact size and number of transactions, e.g. a single byte load produces a single byte read, two neighbouring half-word stores produce two distinct half-word writes.
    With respect to ordering, accesses to normal memory may be reordered (within certain bounds), e.g. a load from A followed by a load from B in the program may actually be presented as read B, then read A. Accesses to Device and Strongly-Ordered always appear in the order they are listed in the program; so what's the difference between Device and Strongly-Ordered....
    Device accesses are only ordered with respect to other Device accesses, whilst Strongly-Ordered are ordered with respect to *all* other explict load/stores. e.g load-norm-A, load-dev-B, load-dev-C, load-norm-D could be performed as ADBC, or even DBCA; whilst load-norm-A, load-so-B, load-so-C, load-norm-D must be performed as ABCD.
I think it's all. if I'll have more questions I'll add them in this topic.
Thank you in advance for your answers,
Marco
ps. sorry for my english
0
#2 User is offline   Joseph Yiu
  • Regular Contributor
  • PipPipPip
  • Group: Members.
Posted 11 June 2012 - 11:59 AM
1. After I set up a region, where the MPU saves the informations on that region?
In hardware registers inside the MPU.
2. In the MPU Region Attribute and Size Register the bit C (cachable) refers only to an external cache, right? Because CM3 doesn't have a cache.
Yes, correct.
3. In the same register, if TEX=b000 C=1 B=1 we have "Outer and Inner write back. No write allocate". What it means "No write allocate"?
Write allocate : If a cache controller is present, it can allocate a cache line for this data and read the rest of the data in this cache line. So next time a nearby data (in the same cache line) is accessed, the data is already in the cache. Write allocate is usually used with write back cache scheme.
No-write allocate is usually use with write through cache.
4. I found that post on the "Strongly Ordered" memory type. is it correct?
This description is from architecture point of view. However, I think the example at the last section seems incorrect. Ordering of normal data access and device/strongly order memory might not need to be retained (Note: ARMv7-M architecture reference manual revision D is updated to be consistent with ARMv7-A/R in this aspect). Ideally you should read the full text in ARMv7-M architecture reference manual.
However, in Cortex-M3 the design is relatively small and there is no re-ordering of memory accesses.
1. Device memory can be defined as shareable and non-shareable. Memory re-ordering can take place between shareable and non-shareable devices. Strongly-ordered memory does not allow this.
2. In Cortex-M3, a memory write to device region can often be buffered. It means instruction after the write (if not a memory access instruction) could started before the write is finished. However, the processor should not start any other operation after a strongly order write until the write is completed.
regards,
Joseph
2
Share this topic:
Page 1 of 1
