Login
Important information
This site uses cookies to store information on your computer. By continuing to use our site, you consent to our cookies.
ARM websites use two types of cookie: (1) those that enable the site to function and perform as required; and (2) analytical cookies which anonymously track visitors only while using the site. If you are not happy with this use of these cookies please review our Privacy Policy to learn how they can be disabled. By disabling cookies some features of the site will not work.
ARM Community: Completely uninstall DS-5 - ARM Community
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Completely uninstall DS-5 Rate Topic: ****- 1 Votes
#1 User is offline   cps
  • Member
  • Pip
  • Group: Members
Posted 23 May 2012 - 08:10 PM
I'm trying to completely uninstall DS-5 to get back to a clean version of the platform database location. I've tried the standard Windows uninstall procedure, but when I opened DS-5 again after a reboot, my plug-ins were still listed and the platform database is still the same. Then I tried another uninstall, followed by deleting workspace directories, running CCleaner to delete anything in the registry and rebooting. Again, I opened DS-5 to find the platform database still had the changes I made before the uninstall. How do I fix this?
0
#2 User is offline   SamEllis
  • Contributor
  • PipPip
  • Group: Members.
Posted 24 May 2012 - 06:44 AM
DS-5 stores user preferences in %APPDATA%\ARM\DS-5 on Windows (and on Linux in ~/.ds5). APPDATA is an environment variable whose value depends on your operating system. If you have a Windows Explorer open you can type the above into the address box to view that location. Otherwise you can open a command prompt and issue the set command to view all the environment variables and the value of APPDATA. On my Windows 7 system, APPDATA resolves to C:\Users\username\AppData\Roaming.
To clear out everything, just delete the contents of the DS-5 directory. If you specifically only want to clear our the configuration database, then try just deleting the DS-5\configdb directory and it will regenerate the next time you start Eclipse. If you do delete the entire DS-5 directory, be aware that you might want to make a copy of the DS-5\licenses directory, as this contains any product licenses that you have installed; you can either put this directory back afterwards or use the ARM License Manager accessible from Eclipse's Help menu to re-install your licenses.
To my knowledge, none of the tools within DS-5 writes to the registry, with the exception of the product installer.
0
#3 User is offline   scott
  • Regular Contributor
  • PipPipPip
  • Group: Members.
Posted 24 May 2012 - 08:42 AM
瀏覽文章引用框(cps @ 23 May 2012 - 08:10 PM)
If you are talking about the list of directories in Window > Preferences > DS-5 > Target Database, the list is stored in the workspace. There is a "Restore Defaults" button in the Preference pane.
0
Share this topic:
Page 1 of 1
