Quick Links
problem with using Streamline on RTSM
#1
Posted 20 March 2012 - 07:03 AM
We are trying to use Streamline with RTSM.
We follow the instructions on http://infocenter.ar...424-/index.html to prepare the kernel and build the gator.
Here are the steps we did:
1. Prepare the kernel
export PATH=$PATH:/home/userdir/DS-5/bin
export CROSS_COMPILE=${CROSS_TOOLS}/bin/arm-none-linux-gnueabi-
export ARCH=arm
cp /home/userdir/RTSM/distribution/kernel/linux-2.6.38-patched-rtsm/configs/V7 /home/userdir/RTSM/distribution/kernel/linux-2.6.38-patched-rtsm/source/arch/arm/configs
cd /home/userdir/RTSM/distribution/kernel/linux-2.6.38-patched-rtsm/source
make V7
make menuconfig
make -j5 uImage
2. build the gator
make -C /home/userdir/RTSM/distribution/kernel/linux-2.6.38-patched-rtsm/source M=`pwd` ARCH=arm CROSS_COMPILE=${CROSS_TOOLS}/bin/arm-none-linux-gnueabi- modules
3. cp gatord and gator.ko into the RTSM
We have the problem that we could not connect Streamline with RTSM's gator daemon. The problem we guess is that when RTSM is launched, it loads a default kernel that is not we generated in step 1. Hence the gator generated in step 3 mismatches with RTSM's kernel. But we do not know how to deal with this issue and make the Streamline work with RTSM. Any help is appreciated very much!
Thanks.
#2
Posted 20 March 2012 - 07:43 AM
The reason that we do not enable Streamline by default to run with the RTSMs is because the RTSMs supplied with DS-5 do not accurately model the internal implementation of an ARM processor. This means that performance data such as cache misses or branch predictions might not be valid. Even if you do get Streamline working, the results might not be useful.
#3
Posted 20 March 2012 - 12:42 PM
If I understand correctly, we need to follow the instructions in the "ARM DS-5 using ARM Streamline>Setting up an ARM Linux target" sections. I paste them as following:
Prepare and build your kernel
To prepare your kernel for use with Streamline, download the desired version of the Linux kernel, configure it to your target platform, customize it, and then build it. To do so, follow these steps:
- Download your desired version of the Linux kernel. For example:
wget http://www.kernel.or....6.35.7.tar.bz2 - Unzip the Linux kernel. For example, enter the following command:
tar xjf linux-2.6.35.7.tar.bz2 - Navigate to the root source directory of the Linux kernel. For example, enter the following command:
cd linux-2.6.35.7 - Enter the following command in your shell to export the cross compiler:
export CROSS_COMPILE=${CROSS_TOOLS}/bin/arm-none-linux-gnueabi- - To specify that this build is for an ARM architecture, enter the following command in your shell:
export ARCH=arm - Enter the following to build the configuration file specific to your platform:
make platform_defconfig
Replace platform_defconfig in the command with one of the configuration files located in theyour_kernel/arch/arm/configs directory appropriate for your platform or with a configuration file provided by a vendor. - To configure menus, enter the following in your shell:
make menuconfig
You must enable certain kernel configuration options to run Streamline. The location of some of these options depends on your kernel version:
General SetupEnable the Profiling Support option.
Kernel HackingEnable the Trace process context switches option.
Kernel FeaturesEnable the High Resolution Timer Support option. Enable Use local timer interrupts if you are using aSymmetric MultiProcessing (SMP) target.
Note
The Trace context switches and events option is not be visible if you have other Tracers configuration options enabled. Enabling other Tracers configuration options is sufficient to turn on context switches and events and run Streamline. - Use the following command to build the image:
make -j5 uImage
If it is true, I believe we did this and get uImage file. I guess it is the kernel image. Hence we replace it with RTSM_EB_V7.axf in DS-RTSM/distribution/boot/RTSM/RTSM_EB_V7. And we get the following error when launch RTSM:
Failed to load application 'boot/RTSM/RTSM_EB_V7/RTSM_EB_V7.axf' into instance 'coretile.core.cpu0':
CADIXfaceBypass() returned CADI status 'GeneralError'.
Error message returned by CADIXfaceGetError:
Error in CADI: while loading application file boot/RTSM/RTSM_EB_V7/RTSM_EB_V7.axf:
boot/RTSM/RTSM_EB_V7/RTSM_EB_V7.axf: file format not recognized (supported formats are: 'ELF, S-Record, Intel-Hex')
So I think maybe we are wrong. And we also find the README.txt in arm/linux_distribution, but we have no idea how to get the sources for the kernel image and we can not find rtsm.zip in DS-5 directory.
Would you please give us some more hints how to get the sources and rebuild the kernel and filesystem etc.
Thank you.
This post has been edited by argon: 20 March 2012 - 01:20 PM
#4
Posted 21 March 2012 - 08:41 AM
So Streamline (or any other tool that uses the PMU) won't be able to gather much data, and what data it can gather from the PMU won;t be accurate.
#5
Posted 22 March 2012 - 07:00 AM
I understand. However, we still would like to try to use Streamline and see some profiling results (even they are inaccurate etc.) before we get the hardwares.
Best,
#6
Posted 23 March 2012 - 09:03 PM
I have not tried building the kernel myself so the advice I can give is quite limited. Regarding the sources for the kernel image, they are available as a separate download from the ARM website. Here is the URL:
http://www.arm.com/p...5-downloads.php
You probably want the file named DS-5 RTSM Linux Example Distribution. You may have to log-in to the ARM website to download this.
