Hi all,
I'm currently working on an a MIPS target which does not support powervr, and it supports MALI. I want to run QTOPEN GL ES1.1 sample appication on my target, at present QT open gl is using powervr. how can i configure QT to use MALI driver, should i write a plugin for QTOPEN GL & MALI, if so how.
Page 1 of 1
MALI driver for QT open GL Configuring QTOPEN GL 1.1 to use MALI driver
#2
Posted 20 January 2011 - 12:30 PM
Hi Prabhuram,
both PowerVR and Mali support the same OpenGL-ES 1.1 API, so if the application just uses the OpenGL-ES 1.1 API it should be possible to run the application on the MIPS/MALI platform where the application will find and use the MALI OpenGL-ES 1.1 drivers.
Hope this helps, Pete
Mali Ecosystem
ARM Media Processing Division
Share this topic:
Page 1 of 1
Share this
