Login
Important information
This site uses cookies to store information on your computer. By continuing to use our site, you consent to our cookies.
ARM websites use two types of cookie: (1) those that enable the site to function and perform as required; and (2) analytical cookies which anonymously track visitors only while using the site. If you are not happy with this use of these cookies please review our Privacy Policy to learn how they can be disabled. By disabling cookies some features of the site will not work.
ARM Community: Cycle penalty - ARM Community
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Cycle penalty Rate Topic: -----
#1 User is offline   armuser
  • Member
  • Pip
  • Group: Members
Posted 10 December 2010 - 04:29 PM
I am wondering where i can find the information regarding cycle penalties for cache misses.
For instance, if an instruction that is going to be executed is not in cache, how many cycles more it will take to execute? (I'm thinking that its execution time will be the number of cycles in the reference manual for this particular instruction, plus the cache-miss penalty)
Further, in an instruction like "str r3, [fp, #-16]", if the memory location ([fp, #-16]) is not in the cache, how many cycles more will it add to the execution time?
Sorry, didn't find this information in the datasheet..
Thanks.
0
#2 User is offline   isogen74
  • Super Contributor
  • PipPipPipPip
  • Group: Members
Posted 10 December 2010 - 10:30 PM
I'm afraid this will have the immortal answer "it depends" ...
Memory latency depends on the internal bus topology of the device, the clock rate of the bus relative to the CPU, the type of memory connected to the device, bus contention, etc.
If it's not on the data sheet, I'd suggest writing some benchmarks to find out (if it is an A-profile core and you can run Linux then LMbench3 includes some good memory benchmarks which give latency and bandwidth).
Pete
When optimizing software, consider that the quickest code to run is the bit you removed from the call path.
0
Share this topic:
Page 1 of 1
