Login
Important information
This site uses cookies to store information on your computer. By continuing to use our site, you consent to our cookies.
ARM websites use two types of cookie: (1) those that enable the site to function and perform as required; and (2) analytical cookies which anonymously track visitors only while using the site. If you are not happy with this use of these cookies please review our Privacy Policy to learn how they can be disabled. By disabling cookies some features of the site will not work.
ARM Community: Out of Memory while linking - ARM Community
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Out of Memory while linking Rate Topic: -----
#1 User is offline   ElliottSteven
  • Member
  • Pip
  • Group: Members
Posted 05 September 2010 - 02:55 AM
hi
While doing a ARM build using RVCT 2.2 patch 686, I am getting the following error
Fatal error: L6000U: Out of memory.
Not enough information to list image symbols.
This is a symbian build.
__________________________________________________
This post has been edited by SeanCrossan: 07 September 2010 - 09:02 AM
0
#2 User is offline   scott
  • Regular Contributor
  • PipPipPip
  • Group: Members.
Posted 08 September 2010 - 11:02 AM
瀏覽文章引用框(ElliottSteven @ Sep 5 2010, 03:55 AM)
I'm guessing that the problem is that you need more memory. How much do you have? How big did the armlink process get?
You can try typing the error message into a web search engine, which should find this Knowledgebase article http://infocenter.arm.com/help/index.jsp?t...aqs/ka4090.html
0
#3 User is offline   kunalm
  • Member
  • Pip
  • Group: Members
Posted 25 October 2010 - 02:34 PM
瀏覽文章引用框(scott @ Sep 8 2010, 11:02 AM)
I presume this is happening for a debug build?
If so, try adding "--remove_unneeded_entities" to your compiler command line
0
Share this topic:
Page 1 of 1
