Hi all,
I have been trying to use the Mali emulator on my laptop using the Beta version 1.2.
Everything is installed correctly but at runtime, when I try to create the context (using eglCreateContext), I'm always receiving the error 0x3005 (EGL_BAD_CONFIG).
For testing purpose, I have reduce to the minimum the aEGLAttributes in order to get the maximum EGL config and I have tried to initialize all of them without sucess.
I have already used this SDK on another laptop with windows XP and it's works fine with the default configuration.
I have done two trial on my laptop and a desktop both with windows 7 and it's the same results.
Both computer are in 64bits with NVIDIA graphic cards (310M and 250 GTS).
I have no clue on how to solve this issue. May be the runtime lib are not compatible with the windows 7/64bits architecture...
Thanks,
Ben
Page 1 of 1
Help on eglCreateContext error 0x3005 Help using VS2008 eglCreateContext error 0x3005 with Windows 7
#2
Posted 13 July 2010 - 12:51 AM
LittleBen, on Jul 12 2010, 07:44 PM, said:
Hi all,
Thanks,
Ben
Thanks,
Ben
I have finally found the issue.
in cube.c, the following code is miss placed :
#ifdef _WIN32
hWindow = create_window(uiWidth, uiHeight);
#else
hWindow = create_window("OpenGL ES 2.0 Example on a Linux Desktop", uiWidth,
uiHeight, hDisplay, sEGLDisplay, aEGLConfigs[0], &colormap, &pVisual);
#endif
it should be before
#ifdef _WIN32
hDisplay = GetDC(hWindow);
#else
hDisplay = XOpenDisplay(NULL);
#endif
for the windows case.
But I don't think the linux case will still works
Cheers,
Ben
#3
Posted 30 September 2010 - 09:08 PM
Hey,
I've had exactly the same problem with OpenGL ES 2.0 Emulator v1.2 [23-Jul-2010] on my Vaio SZ2M/B with GeForce Go 7400 running Vista, so many thanks for posting the solution.
It might be worth noting that you also changed
hDisplay = GetDC(NULL);
to
Carl
to
Carl
Share this topic:
Page 1 of 1
Share this
