It looks the forum is quite new so I'm not sure if this is the right place to post my technical questions.
I'm having problems to compile Mali 400 driver for Linux. The code I got is version r1p0 and I can not get the kernel driver compiled with the kernel code I plan to use 2.6.32. There are some head file missing but the biggest problems comes from the data structure changes in vm_operations_struct inside the kernel. I could not find which kernel version the DDK supposed to work with but obviously there are something changes needed with latest kernels.
I'm wondering if any one have met same problems and is there any one know there is any patch or release can work with kernel 2.6.32?
Thanks.
-Tim
Page 1 of 1
Help needed to compile mali 400 DDK
#2
Posted 29 April 2010 - 10:26 PM
Ok, my problem is fixed with some simple porting efforts. The nopfn handler just print some messages for debugging purpose so it's an easy change
Share this topic:
Page 1 of 1
Share this
