Quick Links
Debug build works but release
#1
Posted 19 January 2010 - 04:32 PM
But release build can't work ( -Otime -O2 -zo )
the code is the same. the compiler is ADS1.2
Do you guys have any idea or previous experience on such an issue?
Thanks.
#2
Posted 19 January 2010 - 04:47 PM
Can you post information about what actually goes wrong, and what the disassembly looks like for the relevant pieces of code from both version you built?
Iso
#3
Posted 19 January 2010 - 08:38 PM
for example, static init code
0x00003724 EB000464 BL pwrp_gio(0x000048BC)
can't be traced into. while execution, the debugger just skip this line directly to next code and seems got no execution
Yet, for public function call
0x00003744 EBFFF8B7 BL HWM_gio_pwrp(0x00001A28)
is OK for both execution and trace into.
in debug build, both functions can be executed and traced into.
BTW, here is a remap operation in my code before pwrp. I copy the image into RAM and run there. Change all RAM memory settings to fit the image.
Iso
#4
Posted 19 January 2010 - 09:31 PM
compiling with "-O2 -g+" will have the effect of causing accesses to behave as though volatile, whilst this behaviour will be optimised out with "-O2 -Otime"; for example:
void foo(void)
unsigned char *f = (unsigned char *)0x100;
*f = 2;
*f = 4;
*f = 6;
Generates three write accesses with debug, but only writes "6" without debug enabled.
Declaring f as "volatile unsigned char*", will result in all three writes always being generated.
If you are talking to peripherals, are you sure you're using the volatile specifier correctly?
hth
s.
#5
Posted 19 January 2010 - 10:57 PM
Now I'm thinking of the runtime init problem. the phenomenon is also debug version works but release build fails.
void foo(void)
*f = 2;
*f = 4;
*f = 6;
hth
s.
#6
Posted 21 January 2010 - 05:25 PM
the root cause is the MCU pwrp config.
but the odd is
debug can work yet release can't.
Seem that Keil ARM debugger can't emulate the MCU 100% behaviors .
