Quick Links
Cycle count in cortex m3
#1
Posted 10 December 2009 - 09:00 AM
I am new to cortex m3...
For my application I need to calculate the number of cycles for a particular function....
I set the debug options as high optimization level and optimize for time....
How can I calculate the MIPS/cycles manually for a particular function.
Please suggest me a solution...
Thanks in advance.
Krish.
#2
Posted 10 December 2009 - 09:50 AM
Run it in a loop a _lot_ of times.
Use a stop watch.
((Seconds * MHz) / Loops) = cycles per loop.
#4
Posted 10 December 2009 - 03:08 PM
Krish, on Dec 10 2009, 01:58 PM, said:
The ISSM for Cortex-M3 is semi-accurate. It models an ideal memory sub-system. Not sure about the pipeline accuracy, but I guess CM3 is simple enough.
If you are really concerned about accuracy, get a cheap eval board and read the cycle count register in the DWT unit.
Regards
Marcus
#5
Posted 11 December 2009 - 08:36 AM
so we can access the DWT only by connecting the board?
I tried like this but did not work....
int count = 0;
int *DWT_CPICNT = (int *)0xE0001008; //address of the register
*DWT_CPICNT = 0; // reset the counter
count = *DWT_CPICNT;
can you please suggest me how to access the DWT unit without the board?
Thanks & regards,
Krish.
#6
Posted 11 December 2009 - 01:19 PM
#7 Guest_Joseph Yiu_*
Posted 11 December 2009 - 06:29 PM
I few things you need to do:
1. Define the registers as "volatile", and "unsigned"
2. Enable TRCENA bit in DEMCR (0xE000EDFC, bit 24) before using DWT
3. You should use DWT's Cycle Count Register (0xE0001004) for timing measurement.
The CPI counter is only 8-bit, and need to have trace support to detect the number of time it overflow.
While the DWT Cycle Count Register is 32-bit.
4. You need to enable the Cycle Count counter.
So based on the code you have prepared, it can be modified to:
int count = 0;
volatile unsigned int *DWT_CYCCNT = (int *)0xE0001004; //address of the register
volatile unsigned int *DWT_CONTROL = (int *)0xE0001000; //address of the register
volatile unsigned int *SCB_DEMCR = (int *)0xE000EDFC; //address of the register
*SCB_DEMCR = *SCB_DEMCR | 0x01000000;
*DWT_CYCCNT = 0; // reset the counter
*DWT_CONTROL = *DWT_CONTROL | 1 ; // enable the counter
count = *DWT_CYCCNT;
I haven't test this code in hardware but it should work.... :-)
The ISSM might not have the detail model of debug components, so it is best to do the timing measurement on actual hardware, either on actual microcontroller or on our FPGA prototyping system.
Note that if the debugger you are using is trying to use this counter at the same time (e.g. if you have got some sort of profiling feature turn on in your debug environment), you might find incorrect profiling result by doing this.
regards,
Joseph
#8
Posted 12 December 2009 - 07:21 AM
I am really very happy for the support from you all.....
Thanks Marcus and Joseph.....
I'll try it and get back to you.......
Thanks....
Krish
#9
Posted 26 January 2010 - 07:36 PM
<disclaimer> I work for Carbon
